displaying pixel values in published image
953
01-30-2023 01:47 PM
AmmaraC
We have images that are published as a dynamic image service with an underlying mosaic dataset, the images are in ArcGIS server. We want to be able to read them into ArcGIS portal into a web map and be able to do the following workaround (https://support.esri.com/en/technical-article/000022286). The result we are trying to achieve is to have the pixel values viewable on the portal.
The problem we’re running into is the popup tools are disabled when reading the images from the image server as a web service in the map. I cannot access or change anything in the popups. Does anyone know how to have pixel values showing when images from ArcGIS Server are in a web map?
Thanks in advance
