Displaying Multiple Polygons On Map With Shared Boundaries
2557
11-29-2013 10:54 AM
AndrewLawrence
Just wondering if anyone might have any advice on how best to display multiple polygons with a shared boundary on a map. I've attached the map I am working on where you can see there are at least three polygons that share the river as a boundary and simply changing the outline width is starting to make the map look a little too busy. I have to admit I am definitely lacking on the cartography side of things since I spend most of my time doing analysis. Any sort of advice would be most appreciated!
[ATTACH=CONFIG]29471[/ATTACH]
EmilySangster1
Some things I would do in your situation might be to give the polygon a fill but make it very transparent so it doesn't interfere too much with everything else that's going on.  If that's not possible having thick but transparent boundaries may also decrease how distracting the boundaries are while still being visible.  I would also consider making the other features in the map which are not the focus of the display much lighter and also more transparent so the most important data stands out best.
If you can, editing the boundaries so they don't fall in the middle of the river would look a little nicer and easier to see.
I'm definitely no expert but I hope I gave you a few ideas to play with!
JohnSobetzer
Honored Contributor
