Disable form configuration in Map Viewer for non-map owners
739
05-07-2024 08:00 PM
Labels (2)
Samuel_McAuley
I have produced several web maps in Map Viewer to enable data editing. I have configured the forms such that only certain fields are exposed for editing and have set requirements on particular fields that are essential to be populated when anyone performs data edits in the map.
However I noticed that anyone who I share this map with, when they open it in Map Viewer, they are able to select a specific editable layer and enter the form configuration section of Map Viewer. From there they are able to add or remove form elements and essentially completely undo all of the form configuration work that I did ahead of time and remove requirements on fields that I want them to be required to fill out. Is there a way to disable the ability for people to modify the form configuration for anyone who is not the map owner?
I am working with ArcGIS Enterprise 11.1
