Difference between ArcServer and Portal
6638
10-07-2015 08:43 AM
JoannFox1
I'm trying to outline the capability differences between ArcServer and Portal and can't seem to find any documentation.  Can anyone point me in the right direction?
JakeSkinner
Esri Esteemed Contributor
Here are some helpful links:
What is Portal for ArcGIS?—Portal for ArcGIS (10.3 and 10.3.1) | ArcGIS for Server
ArcGIS for Server (10.3 and 10.3.1) | ArcGIS for Server
ArcGIS for Server allows you publish your data as services to be consumed in web maps and applications.  Portal for ArcGIS allows you to create web maps/applications that are hosted on your infrastructure.  Portal for ArcGIS is very similar to ArcGIS Online, the main difference is that it located on your own hardware rather than in the cloud.
JoannFox1
Thanks Jake
DerekLaw
Hi Joann,
In addition to what Jake posted, please review these ArcUser technical articles:
Hope this helps,
JoannFox1
Thanks for the documentation Derek - Exactly what I needed
