Dashboard and feature layer
756
08-21-2025 12:24 AM
PaulJohns
Hi everyone, Is it normal behavior for a Dashboard that when I add a web map with a Feature Layer, no objects appear in the Dashboard map frame? I don't have any issues with Web AppBuilder or Experience Builder, but mapping in Dashboard is not available. When I republish the data as a Map Image Layer, all data appears in the Dashboard map frame. However, I need to use a Feature Layer because I must publish data with related tables for analysis.
TanuHoque
@PaulJohns
just an FYI: you should be able to publish a map image layer with related tables. Are you seeing any issues while accessing related records from map services?
TanuHoque
@PaulJohns
PaulJohns
Hi @TanuHoque,
Thank you for your response. You're right, I figured it out a few moments later. However, I've encountered another issue with the dashboard in an offline portal instance. I'll create a new post with a detailed explanation, and I’d appreciate any advice you could offer.
