Customizing the Legend
1286
09-07-2011 01:41 PM
KimballHansen
I displayed my roads with the symbology, categories unique values, feature so that all the roads have a unique color asssociated to them. When I display it in the legend I get a huge list. I only want a few roads on my legend rather than all of them.
Example: I have 10 different state highways each with the same color red. In my legend I only want one red line that refers to all the state highways rather than ten red lines in the legend. I hope someone can help. Thanks.
Kimball Hansen
LeighHolcombe
One thing you could try is duplicating your layer with the ten red roads, and then removing nine of them.  Then you've got a single item which you can customize and add to the legend.  This isn't the most correct way to do it, but it works in a pinch.
HalilSiddique
Within the symbology tab, select all 10 State highways, right click and select Group Values, they should now be grouped as 1 colour and as 1 entry in your legend.
Halil
KimballHansen
Thanks a lot for the help. It was exactly what I needed.
