Creating Dynamic Text w/ Map Series that only shows when needed
248
07-18-2024 07:04 AM
Nathan_WeltyNDOT
I'm working on setting up map layouts in ArcGIS Pro version 3.1.3. These are maps of Counties, and some counties are large enough to require multiple sheets, but most are not. I already set up dynamic text based on the value in the field SheetName to appear on its own line, but I don't want there to be a line there at all if the value in SheetName is null. How would I set it up to have no line? Is there a way to maybe write the expression to have it remove a line if the value is null? Any insight would be appreciated. Thank you!
Here's an example of what we have for counties requiring multiple sheets:7-17-MapSheetConfigProblemA_Image4.png
However, here's what happens if I change to another county in the map series, one only requiring one sheet:
