Create a link with Arcade based on an (1:M relation) , without reopening the same Webmap
1055
06-26-2023 12:27 AM
Manniej
Hello World,
Based on the a related (1:M) table, Enterprise 10.9.1.  I need to define the link to navigate to the source application.
So I do get X (based on available names) separate bullets with links. If I copy/paste the link it is working. But If I click it, to start it within the PopUp, it will open the current WebMap again.
Current result:
I do have a feeling that I still need the concatenate somehow, but I do not get it fit in properly. If I use it at the end, it will cluster the multiple links again.
var relatedtabel = FeatureSetByRelationshipName($feature,"XXXXX.SourceTable",["IDfield"]);
console (relatedtabel)
var related_results = [];
for (var row in relatedtabel){
    push(related_results,"FirstStaticPartOfTheLink" + row.IDfield + "SecondStaticPartOfTheLink");
if(Count(related_results) == 0){
    return "No Info"
var apple = slice(related_results);
return apple;
 Thank you in advanced.
Manniej
@MikeMillerGIS ,  I am really sorry if tagging is considered rude. You did help me immensely with this question.  Would you mind helping me one more time with this question?
MikeMillerGIS
Esri Frequent Contributor
I am not sure, can you create a hosted feature layer sample with a webmap and share it?
Manniej
Thank you for your response @MikeMillerGIS.,  Hereby the map with example data and the arcade expression.
It is content on AGO. Normally it should run on AGS Enterprise 10.9.1.
