Hi
I'm experiencing an issue when trying to edit item properties of a hosted feature service, and then hitting save, the browser icon just spins and freezes. This is on all hosted feature services on a hosted datastore federated with IWA.
For example if I want to enable editing through the item properties, or even change the name of item...
I can, however go through the REST endpoint in server/admin and edit the JSON to reflect the changes that I want, and it works. Just not through the Portal.
Same behaviour with Chrome or IE or FF
What should I be looking at?
Could you let me know the following:
1. Go to My Organization
2. Edit Settings.
3. Security -> Are the following options checked?
Hi Aravind, Yup, both options are checked.
