Cannot create base map layer or group layer
11321
14
10-11-2012 05:27 AM
BenjaminSchumann
I have not used ArcMap for 2 months and suddenly it behaves strange: When starting a new map from scratch, I cannot add a basemap and I cannot create new (basemap or group) layers. I see the option and can click it and there is not even an error message, its just: nothing happens.
Even when adding a basemap, I see the selection window and can select, for example, OSM. But nothing happens after that, the program doesn't even crash...
Any ideas?
I am using ArcMap 10.0
thanks in advance, I could not find anything like this using search.
Ben
JonathanQuinn
Esri Notable Contributor
Thanks for that information.  Go ahead and install Service Pack 5 and see if that resolves the problem.
BenjaminSchumann
I installed service pack 5 but still have exactly the same behavior.
Whenever I start a new project and click "Add Data/Add Basemap", select a map and click "OK", nothing happens.
Also, when loading an existing project with a basemap, it works fine...
Any more ideas? and thanks already so far 🙂
BenjaminSchumann
Right, I found the problem: I had an internet security filter blocking the basemap data.
thanks again
AngelynSnyder
bs804
Is your problem still resolved?
How did you fix the internet security filter issue?
I have been having this same problem for a few weeks. Older map docs with ESRI basemaps work fine, but I cannot add them to new documents.
Could you explain how you resolved this issue?
WilliamCole
I'm having the same problem, though I expect for a different reason.  I'm working my way through learning ArcGIS and probably have done some things in a not correctl way.  Here's a clip of my ToC for this map.  I want to group symbol layers by trip [GWTrip1-Point, GWTrip1-Line].  When I try any of the methods described in the ArcGIS help file under "Working with group layers", none work.  No messages are returned, no actions appear to be taken.  I would be very grateful to know what I'm doing wrong and how to fix it.
Thank you very much ...
