Can we manage versions in Portal with Web ApplBuilder and Smart Editor
1028
06-23-2021 11:29 AM
JoseSanchez
Hello everyone,
Configuration: sde branch versioning
I am able to switch sde versions when pointing to a Portal  Web layer  or a Portal Web Map using ArcGIS Pro. I am following this video and it works:
Editing and Administration with Branch Versioning – It’s Showtime! (esri.com)
My question now is how can I do the same thing with Portal Web AppBuilder and Smart Editor. Is there a way to manage sde versions.  Or should I create a web version in SDE and all the web editor digitize in this version, and then I do the post and reconcile in ArcGIS Pro or in a batch job.
Please advise.
Jose
viplawk
Hi Jose,
Greetings for the day!!
Did u find any solution for the above question?? IF you find any workaround kindly post here. It would be highly appreciated.
Regards
VIP
