Can the Portal add a CSV with non-WGS coordinates to a web map?
2796
03-05-2015 08:42 AM
MichaelGinzburg
I added a CSV file with coordinates in non-WGS CS to a web map.
The web map uses AGS service with the same CS as the CSV, coordinates in the CSV are inside extent of the map.
The Portal has added the CSV as a layer.
When I opened the table of the layer and tried to zoom to a record, the result was scale bar showing NAN NAN NAN and no map was displayed.
Is portal able to add non-WGS CSV?
Thanks!
