Can i Export attribute Table to CSV?
3959
6
12-18-2020 01:26 PM
cardiokan
Hi guys,
I am just wondering if I can export attribute table to CSV?
I have seen this functionality in other apps but can this be done without any type of licence?
Tags (1)
DavidPike
MVP Notable Contributor
I think this is a Portal question rather than Pro.
Attribute Table widget—Portal for ArcGIS | Documentation for ArcGIS Enterprise
There's a checkbox in the Widget, I'm pretty sure there's also the option to export in a Web Map via the attribute table interface,
RickeyFight
DavidPike
cardiokan
Thanks @DavidPike
I have enabled this. Only issue is when I hit export, nothing happens. Will have to see what happens
DavidPike
have you tried with alternate browsers? Does it s[pin or just nothing at all happens? What about checking the browser developer console?
cardiokan
Thanks @DavidPike  Issue was down to firefox and internet edge where this functionality does not work. I tried it in chrome and works fine.
DavidPike
Glad it worked.  The documentation has this:
"For Internet Explorer 8 and 9, you need to manually enter the .csv extension when you save the exported file. For Safari, you need to manually rename the exported file that is saved as Unknown by default."
but no mention of edge.
I've also changed which post you've marked as correct, as changing the browser isn't really the answer to the initial question.
