Hi, I'm trying to figure out the best way to share a lot of layers to Portal.
My features are stored on an SDE inside feature datasets. I need the end URL to end up with the service URL matching the structure in the SDE and featuredatasets:
https://MyPortal.com/server/rest/services/myFeaturedatasetName/myFeatureServiceName/FeatureServer
To do this I can go through any individual layer, share and choose to create a folder or select a folder with the name of my featuredataset name. That would work, but will take for ever.
Theres the batch publishing SDE from inside of Portal, if I use that functionality, it won't honor my feature dataset subdivision all my features will have the same URL only myFeatureServiceName will change.
I could create SDE's with the name of my feature datasets, but that would create a whole new situation, so I don't want to go there
Do you have any suggestions, or is just the long way?
