batch create multiple PDF maps
1611
11-10-2011 05:20 PM
JinfengZhao
Hello all,
I have one layer which attribute table has many fields such as male, female, age groups, ethnicity groups. I need to map each field (variable) into a PDF map, and all maps have same extent. I am using ArcGIS 10. Can anyone suggest a solution to batch create multiple PDF maps? Thanks.
Regards,
Jinfeng
DavidWatkins
Esri Alum
Hi Jinfeng,
Have you looked into arcpy.mapping, the Python scripting module that allows you to update layers and automate PDF export?  I suggest you start with this:
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//00s300000032000000
and this blog post has links to a variety of great resources and samples:
http://blogs.esri.com/dev/blogs/arcgisdesktop/archive/2010/09/24/getting-started-with-python-map-aut...
David
JinfengZhao
Hi Jinfeng,
David
Hi David,
Thank you very much for the information. It is very much appreciated.
Regards,
Jinfeng
RichardDavis1
Seems like Data Driven Pages would help you solve the problem without needing to write script for anything
