arcpy.mapping stuff
4063
6
08-08-2011 09:14 AM
TedCronin
should arcpy.mapping stuff go here, or in python?
TedCronin
Is there a layer limit on how many layers can be listed or limitations with group layers, and or rasters?
TedCronin
running.
import arcpy
from arcpy import env as ENV
from arcpy import mapping as MAP
mxd = MAP.MapDocument (r"C:\beta\Reader_TestReplace.mxd")
for lyr in MAP.ListLayers (mxd):
    print lyr.name
del mxd
Is not working either in wing or py window, currently, or its taking a horribly long time, beyond 10 minutes to print out the lyr.name for layers, group layers and rasters.
this is win7.
TedCronin
So  this took easily 20 minutes to print, is that expected?
All County Parcels (Expand to View) 1:25,000
Draw Without Fill Color
Draw With Fill Color
Section Lines
Page Lines 1:80,000; PgNum: 1:25,000
Centerlines 1:60,000;  stname 1:30000
Major Roads
Highways
Book Boundaries
Cities
County Boundaries
PROP 8 - Agriculture
Ag 2011
Points - Agriculture 2011
Agriculture 2011 1/2 mi radius
Agriculture 2011 1 mi radius
Agriculture 2011 2 mi radius
Agriculture 2011 5 mi radius
Ag 2010
Points - Agriculture 2010
Agriculture 2010 1/2 mi radius
Agriculture 2010 1 mi radius
Agriculture 2010 2 mi radius
Agriculture 2010 5 mi radius
PROP 8 - Commercial
Commercial 2011
Points - Commercial 2011
Commercial 2011 1/2 mi radius
Commercial 2011 1 mi radius
Commercial 2011 2 mi radius
Commercial 2011 5 mi radius
Commercial 2010
Points - Commercial 2010
Commercial 2010 1/2 mi radius
Commercial 2010 1 mi radius
Commercial 2010 2 mi radius
Commercial 2010 5 mi radius
PROP 8 - Condos
Condos 2011
Points - Condos 2011
Condos 2011 1/2 mi radius
Condos 2011 1 mi radius
Condos 2011 2 mi radius
Condos 2011 5 mi radius
Condos 2010
Points - Condos 2010
Condos 2010 1/2 mi radius
Condos 2010 1 mi radius
Condos 2010 2 mi radius
Condos 2010 5 mi radius
PROP 8 - Manufactured Homes
Manufactured Homes 2011
Points - ManufacturedHomes 2011
ManufacturedHomes 2011 1/2 mi radius
ManufacturedHomes 2011 1 mi radius
ManufacturedHomes 2011 2 mi radius
ManufacturedHomes 2011 5 mi radius
Manufactured Homes 2010
Points - ManufacturedHomes 2010
ManufacturedHomes 2010 1/2 mi radius
ManufacturedHomes 2010 1 mi radius
ManufacturedHomes 2010 2 mi radius
ManufacturedHomes 2010 5 mi radius
PROP 8 - Parcels
Parcels 2011
Points - Parcels 2011
Parcels 2011 1/2 mi radius
Parcels 2011 1 mi radius
Parcels 2011 2 mi radius
Parcels 2011 5 mi radius
Parcels 2010
Points - Parcels 2010
Parcels 2010 1/2 mi radius
Parcels 2010 1 mi radius
Parcels 2010 2 mi radius
Parcels 2010 5 mi radius
PROP 8 - Residential
Residential 2011
Points - Residential 2011
Residential 2011 1/2 mi radius
Residential 2011 1 mi radius
Residential 2011 2 mi radius
Residential 2011 5 mi radius
Residential 2010
Points - Residential 2010
Residential 2010 1/2 mi radius
Residential 2010 1 mi radius
Residential 2010 2 mi radius
Residential 2010 5 mi radius
PROP 8 - Timeshares
Timeshares 2011
Points - Timeshares 2011
Timeshares 2011 1/2 mi radius
Timeshares 2011 1 mi radius
Timeshares 2011 2 mi radius
Timeshares 2011 5 mi radius
Timeshares 2010
Points - Timeshares 2010
Timeshares 2010 1/2 mi radius
Timeshares 2010 1 mi radius
Timeshares 2010 2 mi radius
Timeshares 2010 5 mi radius
PROP 8 - Vacant Land
Vacant Land 2011
Points - Vacant Land 2011
VacantLands 2011 1/2 mi radius
VacantLands 2011 1 mi radius
VacantLands 2011 2 mi radius
VacantLands 2011 5 mi radius
Vacant Land 2010
Points - Vacant Land 2010
VacantLand 2010 1/2 mi radius
VacantLands 2010 1 mi radius
VacantLands 2010 2 mi radius
VacantLands 2010 5 mi radius
Waterbodies
MichaelGrossman
Hi. The Map Automation forum is the best place for questions specific to arcpy.mapping [http://forums.arcgis.com/forums/176-Map-Automation].  Or you can post to the Python forum if it is a cross cutting question involving all of arcpy.  But let me take a crack at what you've posted so far...
For the ListLayers problem, is the MXD slow to open in ArcMap, or only slow when accessed using arcpy.mapping outside of "CURRENT"?  If there are SDE based layers, we could have a real problem there.  Please reply with more info or log a bug with repro data attached.
For the printing issue, is it slow to print in ArcMap, or only when printing with arcpy.mapping?  If arcpy.mapping printing is slower than ArcMap printing, you may be using an excessively high value for the "image_quality" parameter by accident.
--Michael
TedCronin
ok, I did not see that forum, so I will post there after this post.  Thank you Mike.  i am hopefully going to be more involved with arcpy.mapping, this is only my second day since beta10 using arcpy.mapping, so bear with me.
The mxd points to SDE data, file GB locally, UNC over a network, and there are about 15 broken links.  opening the mxd, is pretty slow, so it may not be just arcpy.mapping.  Broken Links and UNC are probably the biggest culprits.  i am thinking the speed of the mxd with the broken links, is akin to what we experienced at 9.3 or 9.3.1 where there was a perf hit when you had broken links.
What I mean by printing is not actual printing of the mxd, but printing the list, so I can see the data, so see about replaceWorkspaces.  Is it possible to loop through layers and for the replaceWorkspacePath or the finadAndReplace...use the lyr.dataSource as the input, in place of the actual path, is that feasible?
TedCronin
Are there limits to saving out lyr files, where the name in the MXD has a semicolon or parenthesis in the name?  Meaning no special characters in the name is allowed to save out as layer files...
