ArcGIS Portal Utility Services
1410
01-29-2021 01:25 PM
shay-geo
Hello,
Is it possible to add your own custom geoprocessing services to the Utility Services?https://enterprise.arcgis.com/en/portal/latest/administer/windows/configure-services.htm
I see the Standard list such as Printing, Geometry etc.
But let say, if I have a Custom GP , RouteEnhancer. Could I publish that Toolbox and be able to list it under Utility Services page of the ArcGIS Portal?
Thanks and Regards,
Shailesh Gavathe
by Anonymous User
Not applicable
Hello Shailesh,
Does your geoprocessing service fit into one of the utility service categories listed in the link you included?
Printing
Geometry
Directions and Routing
GeoEnrichment
Orthomapping Elevation
Elevation
Hydrology
Geocoding
If not, then while you can add the tool as an item to your Portal content, it can't be configured as a utility service.
-Calvin
shay-geo
Thank you Calvin.
We configured internal services for below items.
Printing , Geometry
Could it be done in future ESRI release that the custom services could be configured as a Utility Services and we could use Portal Object from ESRI JS API portal.helperServices and access the services?
Shailesh
MarcBate
Is AGOL required in order to use the Hydrology analysis tools in your Portal via the map viewer classic as of 10.9.1?
We would like to avoid using credits and host the service ourselves.
What other analysis tools are currently like this for portal?
