Arcade not Reading all Records When Applying Symbology Based on Time
951
04-11-2021 07:42 PM
TravisMcKee
Hi currently I have a stream that populates a layer with events including time, these can quickly get into the 100000+ records. I am attempting to use Arcade to change the symbology based on how old the record is. My Arcade script works, however it looks like it will only read the first x amount of rows. This means not all the requires symbology is applied. I can only get it to work if I apply a query to limit the displayed data records from a shorter interval, which must be under Arcades threshold. Is there away around this? I have modified the JSON so the required symbology is visible, but it still wont display on the map.
