API Add User with POST URL
1277
08-22-2023 05:28 AM
Amagaad
Hello
Our users sign in via enterprise.
I am trying to make use of the post api to add a user
https://(site)/portal/sharing/rest/community/users/(username)/add
I have tried various formats for the (username). joeblogs@domain, domain\joebloggs.
However every time I get the response 'User does not exist or is inaccessible'.
If I call the api to get the userinfo with joebloggs@domain it works fine e.g.
https://(site)/portal/sharing/rest/community/users/jobloggs@domain
Can anyone help advise? Is the post api add url incorrect?
Many thanks
JakeSkinner
Esri Esteemed Contributor
Hi @Amagaad ,
Are you trying to create a user in Enterprise?  If so, use the createUser command instead.
NicolasGIS
Honored Contributor
Hi @Amagaad,
I guess you found the solution in the meantime but I am sharing my experience for others facing the same issue. I faced it running a migration script of my users from SAML provider to OIDC one. Script was coded using Python API for ArcGIS and adding a 5-second sleep between processing each user solved this issue.
time.sleep(5)
I guess as the error message is a bit misleading !
