I actually recived some data in a FGD that also contained some good and appropriate metadata. I started to create a web map so as to publish the map internally as an example. When configuring the pop-up for one of the layer with the metadata, I find that I am not sure how to access a layers metadata to use in labels, texts, and pop-ups. Is there a method to gain access to the metadata "data" to be used as a varible and the like?
James
