Single-machine deployment with Additional Server and BDS on AWS
1046
08-03-2021 02:34 AM
EnverPekcan
Hello,
Goal is having Single Machine deployment on a base ArcGIS Enterprise deployment with additional server roles (AGS Server+GeoAnalytics Server-->BDS+Geoevent Server+ Image Server-->Server+Hosting Analytics) as pointed as below screen capture.
During the single-machine deployment using the ArcGIS Enterprise Cloud Builder for AWS app creating multiple machines like as Highly Available environment deployment. For roles, number of ArcGIS Server instances selected 1 for each roles.
However, deployment configuration as below: The expectation is that the total number of servers should be 14. However, after the deployment, the number of servers doubled to 28.
The behavior problem of the App is that it is like a multi-machine deployment, not a single-machine deployment.
In addition, the deployment configuration was tried with the CLI and the following error was received.
I find this error message interesting because different EIP's created and allocated for server and geoevent component seperately were available in the config JSON file
[17:59] - Process initiated with batch id : 20210731055941
[17:59] - Validating deployment bucket is in progress.
[17:59] - Validating deployment bucket is completed successfully.
[17:59] - Validate parameters is in progress.
[18:00] - Same EIPAllocationId for node GeoEvent is used for multiple roles in deployment configuration file. Make sure it exists only once for each role.
[18:00] - Exiting the process..............................
I'm waiting your valuable contribution to achieve that deployment with single machine +additional roles.
Thanks
