Server Failed To Authenticate Request - Azure Image Creation
5949
04-13-2015 12:09 PM
AndrewBrown
I've been trying to create the initial image for the AGS on Azure tech preview.
I've downloaded and installed Azure Powershell, I'm running windows 7 with Powershell 3.0.
I have an MS Azure Subscription and I've created the publishsettings file.
I have an ArcGIS Server 10.2.2 installation folder and the provisioning file.
The first errors I got were from line 357 in the agsAzureVMTools.ps1.  The $azModDef variable was looking for Azure.psd1 in this path ....
$azModDef = "C:\Program Files (x86)\Microsoft SDKs\Windows Azure\PowerShell\ServiceManagement\Azure\Azure.psd1"
Yet on my computer, the path to Azure.psd1 was
"C:\Program Files (x86)\Microsoft SDKs\Azure\PowerShell\ServiceManagement\Azure\Azure.psd1"
I modified agsAzureVMTools.ps1 to point to the correct path and it got a little further.
Now I am getting this message.
Test-AzureName : ForbiddenError: The server failed to authenticate the
request. Verify that the certificate is valid and is associated with this
subscription.
Has anyone experienced this problem before?
Andrew
AndrewBrown
Here is the log file generated.
I don't know why it can't find the storage account.  I've tried my original storage, and also created a new storage account.
[04-13-2015 14:53:13.131991] logging to file enabled : D:\Files\Software\ESRI\ArcGIS-On-Azure-TechPreview\Server\logs\Create-Image-13-Apr-2015-T14-53-13.log
[04-13-2015 14:53:13.178791] Current PowerShell version : 3.0
[04-13-2015 14:53:14.010591] Current Azure version : 0.8.16
[04-13-2015 14:53:14.026191] Checking Create-Image.ps1 input parameters
[04-13-2015 14:53:14.057391] Connecting to subscription Visual Studio Premium with MSDN
VERBOSE: Setting: Microsoft.Azure.Common.Authentication.Models.AzureSubscription as the default and current subscription. To view other subscriptions use Get-AzureSubscription
[04-13-2015 14:53:15.835791] Create-Image.ps1 : FAILED
ERROR: Storage account agsazurestorage not found
At D:\Files\Software\ESRI\ArcGIS-On-Azure-TechPreview\Server\PSScripts\agsAzure
VMTools.ps1:446 char:7
+       throw (fls "Storage account {0} not found" -p $StorageAccountName)
    + CategoryInfo          : OperationStopped: (Storage account...orage not f
   ound:String) [], RuntimeException
    + FullyQualifiedErrorId : Storage account agsazurestorage not found
NikhilShampur
Andrew - can u try the following commands in a PowerShell window
Import-AzurePublishSettingsFile <pathToYourFIle>
Select-AzureSubscription -Name 'Visual Studio Premium with MSDN'
Get-AzureStorageAccount 'agsazurestoreage'
Also I would recommend that you rename your Azure subscription.
How to change the name of your Windows Azure subscription | Rick Rainey
