How do I Disable ArcMap Runtime on Azure Cloud Builder
2069
01-31-2022 06:36 AM
AngieCausey
We have an ArcGIS Server 10.8.1 deployment using ESRI's Azure Cloud Builder.  Python 2.7 has been declared as vulnerable, so there are vulnerability findings on our Azure machines.  We have read articles on how to disable the ArcMap Runtime support in 10.9.1 (https://enterprise.arcgis.com/en/server/latest/administer/windows/disable-arcmap-runtime.htm), however, the instructions do not apply (and do not work) for cloud builder deployments.
What is the best way to go about removing Python 2.7 and any ArcGIS Server dependencies on an Azure Cloud Builder deployment?  We are planning to upgrade to 10.9.1 using Cloud Builder, but in doing so we also want to disable the ArcMap Runtime and remove Python 2.7 in the process and have been unable to find documentation on how to properly do this.
ReeseFacendini
Esri Alum
Disabling Python 2.7 is an option only for deployments of Enterprise 10.9.1.  Any earlier versions, 10.9 or before, will not have that option present.  10.8.1 doesn't have any settings to be modified post installation, which is why that option is grayed out
ReeseFacendini
Esri Alum
The instructions that you have linked to above, and under the first section of "Modifying an installation" will work with a Cloud Builder environment, once the upgrade to 10.9.1 has been completed.  Cloud Builder makes deploying the software more automated, it doesn't change how the software functions after being deployed.
AngieCausey
On the current 10.8.1 deployment (Windows), when I go to ArcGIS Server 10.8.1 the Modify option is disabled.  Will that not be the case after I upgrade?
ReeseFacendini
Esri Alum
AngieCausey
Excellent!  We plan to perform the upgrade this Wednesday and will follow the instructions as recommended.  After we are successful, I will accept your solution in this post.  Thank you!
