Failed to create stack - ArcGIS Enterprise Builder for AWS
1991
12-07-2020 06:12 AM
BartłomiejGajc
since many days I am struggling with the following error while using ArcGIS Enterprose Builder for AWS (10.8):
Message :Failed to create stack 'WWFDEPortal-BaseEnterpriseStack' because of following errors.
Logical ID : WWFDEPortal-BaseEnterpriseStack, Status Reason : The following resource(s) failed to create: [WaitCondition].
Logical ID : WaitCondition, Status Reason : WaitCondition timed out. Received 0 conditions when expecting 1
What is wrong there? I have SSL cert, the validation done by the Builder is ok and after almost 5 hours of creating the deployment I get the error. I also see in WAS console that it creates EC2 instance with a "BaseEnterpriseStack" suffix. Is this the final EC2 instance with the Portal running? It has not got allocated the EIP which was chosen in the Builder.
Does anyone know what is going on there? I tried to use the Builer on different desktops, different Amazon account. All these deployment fail.
JonathanQuinn
Esri Notable Contributor
You'll need to get onto the EC2 machine and check the chef log. That'll tell you why the deployment is failing.
