Datastore validation fail due to server machine not found
1311
11-01-2023 11:16 PM
ChenxinHu
Hi Guys,
We're building a high availability enterprise system on AWS. It's working when it first setup, but after rebooting the server and datastore machine and try to validate the datastore, it failed.
Checked log and found the error message as follow:
The connection property set was missing a required property or the property value was unrecognized.   Server machine not found[]
Anyone has any idea how to fix this?
MikeSchonlau
When you reboot, the Primary role switches to the Standby machine. Did you try running a "describedatatore" command on the *new* Primary Data Store machine? That should give you more details
Dan_Brumm
maybe obvious but, after the reboot are all your ESRI window services started? All of my services were set to manual by default and caused some issues when we first stood our system up.
Daniel Brumm
GIS Nerd
