CloudFormation Templates do not import
1606
04-06-2024 12:36 PM
JoeHershman
I was trying to use CloudFormation and get errors trying to import the esri templates.  Using this template:
https://arcgisstore.s3.amazonaws.com/1110/templates/arcgis-enterprise-allinone.template.json
I get the following errors
This makes it impossible to use.
Thanks
-Joe
-Joe
MikeSchonlau
Are you able to share any of the parameters you used to fill in the template? Or did this error appear before you even got that far? I used this same template successully in Feb, so I'm wondering if there is a parameter that is causing you trouble.
JoeHershman
Don't even get that far, this is just trying to load the template at the very start, before I could even make changes
-Joe
MikeSchonlau
Which AWS region are you trying this in? I can try to replicate it
