I was trying to use CloudFormation and get errors trying to import the esri templates. Using this template:
https://arcgisstore.s3.amazonaws.com/1110/templates/arcgis-enterprise-allinone.template.json
I get the following errors
This makes it impossible to use.
Thanks
-Joe
Are you able to share any of the parameters you used to fill in the template? Or did this error appear before you even got that far? I used this same template successully in Feb, so I'm wondering if there is a parameter that is causing you trouble.
Don't even get that far, this is just trying to load the template at the very start, before I could even make changes
Which AWS region are you trying this in? I can try to replicate it
Signed in members can post, follow updates, and more. New here? Register a free account.
