AWS Cloud Formation Allowed Instance Types
1458
04-17-2025 06:00 PM
SiCasley
Looks like the Cloud Formation templates for Enterprise 11.3 are missing some of the newer instance types, such as m6i and m7i. Is there any reason for this?
i.e. https://arcgisstore.s3.amazonaws.com/1130/templates/arcgis-server-ha.template.json
Any issue in modifying the template to include these other types?
NCCGIA
We've run into the same circumstance (especially as time goes on w/o upgrading) and we've just created new launch template and specify a different instance type.
MarceloMarques
when I ran into this. I create the deployment using for example m5.2xlarge, then after the deployment is completed and I check that everything is working ok, I power off the machines and change the instance type.
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career.." | “ The mountains are calling and I must go.” – John Muir |
NCOneMap
That definitely is a convenient method if not in an autoscaling environment. You would also need to be careful about the changes to ephemeral storage drives if serving imagery using raster proxies.
