ArcGIS Enterprise 11.2 on Kubernetes namespace error
1023
02-08-2024 03:11 AM
JamalJackson
Hello, I am attempting to deploy ArcGIS Enterprise 11.2 on Kubernetes, in a disconnected environment. I am using CentOS9, running podman version 4.8.1, kubectl version 1.29, kustomize version 5.0.4-0. When I kick off the [deploy.sh -f deploy.properties] I am cannot get past the validating namespace check.  I verified the container I designated in the properties file is listed as running under podman yet I constantly receive the "any provided namespace" doesn't seem to exist. I have noticed that when I run [kubectl get namespace] I cannot connect to server API group list or connect to server which are both set as local host. Can anyone assist this noob?
TrevorSeaton
Hi Jamal, given the detailed scenario and likelihood the environment configuration is involved here, potentially beyond the software, we would recommend contacting Esri Technical Support directly to help with diagnosing. You may have already done this; sorry we did not reply earlier here to your post.
