This enhancement request would be rendered irrelevant and impossible when server is federated to a portal, since a federated server can have only one webadaptor. Since Pro will currently only publish via Portal to a federated server, multiple webadaptors are unavailable in that environment anyway. So, in voting FOR this idea, I'm also endorsing the prerequisite concept that a server be allowed to have multiple web adaptors even when federated. Alternatively, if publishing directly from ArcGIS Pro to Server is enabled, then federation would not be necessary, and multiple web adaptors would continue to be possible in the ArcGIS Pro environment, this would then make this enhancement relevant going forward.
