Support Swagger for ArcGIS Server REST endpoints
16521
15
02-27-2013 06:14 PM
Status: Open
DaveTimmins
The current REST API endpoints for the ArcGIS server services directory and administration allow you to get some useful information and test operations but the documentation is very basic and when complex inputs are required there is no help at all really. By adding Swagger support you could provide the user with a much richer experience and make the API more self documenting.
15 Comments
JenniferLang
It seems like many other APIs have a swagger page. Why hasn't ESRI followed industry best practice. I'd love to learn how it use it better and I find I learn better if I'm doing rather than reading pages and pages of documentation.
RPW
We also require Swagger / Open API support for our ArcGIS Server REST endpoints to register our web services with Azure API Management and data catalogues. Currently, we need to create Swagger files manually, and are considering developing a tool that could automate this process. However, it would be much easier if ArcGIS Server supported the Open API standard by default. I understand that GeoEvent Server supports Swagger, so there seems to be partial Esri support for it.
If anyone has tips or more information, it would be highly appreciated.
LaurensKusse_hhdelfland
I thought Esri finally solved this issue by implementing OGC feature service.
I tested this service-type (with ArcGIS Enterprise 11.3) and it does provide a json that says "openapi": "3.0.3" and a html that says:
The API document provides a machine processable description of this service API conformant to api 3.
Unfortunately it still is not OpenAPI compliant. So you can't import it into Swagger or Azure APIM.
Support told me this request is accepted for one of the coming releases: ENH-000122818: Request to support an OpenAPI specification with the ArcGIS REST API  (I can't find this enhancement myself. Maybe I don't have access)
If anyone has tips or tricks how to create a correct json, from the OGC Feature-service-json, that would be appreciated.
I tried comparing with OGC feature services with a correct OpenAPI specification, that I found over here: https://api.hamburg.de/datasets/v1
But I'm not yet successful.
I managed to alter the json that the Esri OGC Feature-service provides. Now I can import the json into Swagger or Azure APIM without errors. It works, but I'm not sure if all the parameters are correct.
The main issue was that the json contains references without the item that it refers to. So that is what I added. Azure APIM also didn't agree with the 200 response. So I changed that too.
replace this:
"schemas": {}
with this:
        "parameters": {
            "f": {
                "in": "query",
                "name": "Whatever name you like",
                "schema":
                    {"type": "string"}
        "schemas": {
            "LandingPage":
            "Conformance":
            "Collections":
            "collectionInfo":
            "htmlSchema": {
                "type": "string",
                "example": "<html>...</html>"
 And this:
"200": {
    "description": "successful operation",
    "$ref": "#/components/schemas/LandingPage"
with this:
                    "200": {
                        "description": "The operation was executed successfully.",
                        "content": {
                            "application/json": {
                                "schema": {
                            "text/html": {
                                "schema": {
                                    "$ref": "#/components/schemas/htmlSchema"
                    "400": {
                        "description": "Bad Request"
                    "406": {
                        "description": "Not Acceptable"
                    "500": {
                        "description": "Server Error"
JoshuaBixby
Twelve years and still waiting....  I would say still hoping, but I think I have given up hope.  The need for this has been covered by earlier comments, so I won't repeat them again.
