Support Credential-Free Identity (Managed Identity) Between ArcGIS Enterprise and User-Managed Databases
425
02-22-2026 05:16 PM
Status: Open
CameronIrvine
I would like to see supported added for credential-free identity between ArcGIS Enterprise and user-managed enterprise geodatabases using cloud-native workload identity (for example, managed identities).
For Azure deployments, this would mean allowing ArcGIS Enterprise on Kubernetes to authenticate to databases such as Microsoft Azure SQL Database using a managed identity issued by Microsoft Entra ID, rather than requiring a stored username and password.
Background
Many of our customers operate in regulated environments and must meet security frameworks such as the Australian Cyber Security Centre Essential Eight Level 2 (E8 L2). These frameworks increasingly require:
  • Mandatory MFA for identities
  • Removal of stored credentials where possible
  • Adoption of passwordless authentication
  • Strong conditional access controls
  • Centralized identity governance
ArcGIS Enterprise currently supports Entra ID–based authentication for some database scenarios, but system-to-system connections still require a service account with a password. Because the connection is non-interactive, MFA cannot be enforced, and credentials must be stored and rotated, creating both compliance and security challenges.
Problem
For cloud deployments (particularly ArcGIS Enterprise on Kubernetes):
  • Database credentials must be stored in secrets
  • MFA cannot be applied to service accounts
  • Password rotation introduces operational overhead and outage risk
  • This approach does not align with Zero Trust or modern cloud identity practices
  • It creates audit challenges for organizations pursuing Essential 8 L2 or similar compliance targets
Proposed Enhancement
Enable ArcGIS Enterprise to use managed identity / workload identity for database connectivity.
Example Azure flow:
ArcGIS Enterprise Pod → Managed Identity → Entra ID token → Azure SQL DB
This would eliminate stored credentials entirely and allow authentication using short-lived tokens issued by the identity provider.
Benefits
Security
  • Eliminates stored database credentials
  • Enables passwordless system authentication
  • Aligns with Zero Trust architecture
Compliance
  • Supports Essential 8 L2 and similar frameworks
  • Improves audit posture for privileged access
  • Aligns with MFA and Conditional Access strategies
Operational Efficiency
  • No password rotation required
  • Reduced secret management overhead
  • Lower risk of outages from expired credentials
Cloud Alignment
  • Aligns ArcGIS Enterprise with modern cloud-native patterns
  • Matches capabilities available in other enterprise platforms
  • Improves adoption in regulated cloud environments
Suggested Initial Scope
  • ArcGIS Enterprise on Kubernetes
  • Azure SQL Database / Azure SQL Managed Instance
  • System-assigned and user-assigned managed identities
Business Impact
This capability would significantly improve ArcGIS Enterprise adoption in regulated industries and government environments where passwordless and credential-free architectures are becoming mandatory rather than optional.
Thank you for considering this enhancement.
Cameron
