Request to support adding secured WMTS services in Map Viewer, similar to ArcGIS Pro.
961
07-03-2025 01:59 AM
Status: Open
SunkubbDev
I need to add the WMTS Service in the map viewer, but I receive an error 'Access-Control-Allow-Origin'. WMTSportal.pngWMTSPro.png
I can add the same service in ArcGIS Pro 3.5.1.
I suppose this issue is a limitation.
Please help add the WMTS service to the ArcGIS Enterprise portal map viewer.
2 Comments
kntr
I also have this issue with a WMTS from another organization. When I add a WMTS server connection in Pro, it prompts for username & password authentication. However, the same is not available when adding a WMTS service into Portal. In 2025, Esri should be able to do this already as basic map viewing (with web services) workflows have shifted from desktop to web clients already.
GIS-Chris
@SunkubbDev@kntr  I'm pretty sure this actually works allready. Have you added the domain in the list of trusted servers (Organization-->Settings-->Security-->Trusted Servers)?
