As part of Bulk published and setting styles to features in Portal (10.7.1) - the styles are very limited and need to be similar or close to what is available in ArcPro or ArcMap. The styles in Portal are limited to a solid fill and stripling or hatching is not available ? It would be good for the next release to expand the styles available through Portal to assign to features that have been bulk published..
