Offer recommended system configurations on Virtual Machines
1852
04-01-2010 09:36 PM
Status: Open
RajendraDutt
This could be a great way for ESRI to showcase and allow clients to test their internal configurations against ESRI's recommended optimized systems.   In enterprise arena system performance has been the sore point for supporters of ArcGIS Server.  Optimized virtual machines with recommended configurations would allow them to play against a working solution.
5 Comments
CarlosColón-Maldonado
Totally agree, especially using the latest ArcGIS Runtime SDK for Java (Linux) in a development environment. The rumor is that some have failed and some suceeded at tweaking VMs get it to work.
EsriAGSIdeas
There is currently a document on how to configure ArcGIS Server using VM Ware and it can be found here:
http://www.vmware.com/resources/techresources/10091
DEWright_CA
The problem with relying on documents with recommended specs is that its very subjective; different use cases mean the specs of a machine can change.
MarceloMarques
@RajendraDutt -
Introducing the ArcGIS Well-Architected Framework (esri.com)
Successfully designing, implementing, and operating enterprise systems in today’s Information Technology (IT) landscape often requires extensive knowledge and expertise in both technology and in the business objectives the systems are intended to support. The ArcGIS Well-Architected Framework and Architecture Center website strives to empower you as IT professionals, architects, support team members, and GIS professionals with foundational information about ArcGIS, and guide your organizations in making knowledgeable decisions when implementing systems with ArcGIS.
You can visit this website now at: https://architecture.arcgis.com.
