map.getLevel() should return absolute level, not relative level
1235
08-16-2011 06:57 AM
Status: Open
JeffPace
In the Javascript API (at leasst) map.getLevel() returns a relative level.  For example, if your absemap contains levels 0-18 (i.e google or bing ) and you specify LODS in your map creation of levels 9-18, zooming to level 10 will return map.getLevel() = 1 (it is the second level in the map).  This is very counterintinutive and does not work well for intergrating with other maps.
I would suggest map.getLevel() with optional parameter type: absolute or relative, with absolute as the default.
1 Comment
SiqiLi
by Esri Contributor
Tested with Flex API and its Map.Level() method also returns a relative level ID, which is 1.
