NOTE: ArcGIS Enterprise ideas require a single label. See the descriptions to choose the label that best aligns with your idea submission.
Under Consideration | Currently (as of release 11.1) service webhooks only support non-hosted data (data in an enterprise geodatabase) wher... by NielsVemmelund1 New Contributor III 8 1 | 8 | 1 | |
Under Consideration | It would be a great enhancement if administrators were able to prevent users from creating new folders within the RES... by MichaelClifford New Contributor II 12 6 | 12 | 6 | |
Under Consideration | Services come and go. They serve their purpose or are replaced by a more authoritative source and are deleted. Client... by stevegourley Occasional Contributor II 28 9 | 28 | 9 | |
Under Consideration | I would like to see an interface for admins under the organization tab of ArcGIS Enterprise to pick which categories ... by JamesTchorzynski1 New Contributor III 4 3 | 4 | 3 | |
Under Consideration | For an administrator of an ArcGIS Portal, it would be useful to have the ability to sign in as another user.This func... by SimonReman2010 New Contributor II 7 3 | 7 | 3 | |
Under Consideration | Hello In ArcGIS Manager , it's possible to import a new service from a SD file. It should be usefull to export a s... by xavierlhomme Occasional Contributor 4 2 | 4 | 2 | |
Under Consideration | Everyone wants a way to track their content interconnectedness and understand implications of content changes.Please ... by COSPNWGuy Occasional Contributor II 9 5 | 9 | 5 | |
Under Consideration | As what seems to be a standard workflow, we invite users to our organizational ArcGIS Online account simply by using ... by MichaelSnook Occasional Contributor III 4 1 | 4 | 1 | |
Under Consideration | In the Kubernetes version the /admin/userstatistics endpoint seems to be able to provide metrics in Prometheus format... by RogerLindholm New Contributor II 2 2 | 2 | 2 | |
Under Consideration | Please add an option to the ArcGIS Enterprise installation to NOT install the default portal items. It adds an unnece... by JoeHeggenstaller New Contributor III 9 3 | 9 | 3 | |
Under Consideration | When moving content across tiered ArcGIS Enterprise Environments, non-hosted feature layers are not included. Refrenc... by Anonymous User Not applicable 8 2 | 8 | 2 | |
Under Consideration | ArcGIS Portal really needs the capability to create and manage relationship classes in the web interface of ArcGIS Po... by Joshua-Young Occasional Contributor III 14 4 | 14 | 4 | |
Under Consideration | Create a Collaboration Unsupported Content List and add it as an 'i' button in collaboration so admins can see the li... by LukeSavage Occasional Contributor II 13 2 | 13 | 2 | |
Under Consideration | When creating a new WebApp thru Portal/AGO, if you choose the WebApp Builder any related table data neatly appears at... by ChristopherBowering Occasional Contributor II 5 1 | 5 | 1 | |
Under Consideration | Grreetings,Publishing in Bulk from a ArcGIS Data store item is incredibly convenient. That being said, we noticed ver... by JoeGuziStarkCountyOH Occasional Contributor 13 2 | 13 | 2 |
Idea Submission Guidelines
User | Count |
9 | |
8 | |
6 | |
4 | |
4 |
