Export as SD file
1916
09-28-2022 06:26 AM
xavierlhomme
Hello
  In ArcGIS Manager , it's possible to import a new service from a SD file.
  It should be usefull to export a service as a SD file, in order to publish the same service in another server. This functionalality combined with the possibility to update datasource ( remplacement editor , publish datasource)  could be use in order to publish the same Service from Staging to Production...
best Regards
Tags (1)
3 Comments
jill_es
DeanMoiler
Really good idea. +1 Would be useful to be able to export the sd, rather than grabbing the mapx from the service directory and publishing, as you wouldn't need to go into pro.
ChrisWozniak
I 100% agree. I'm very archive-y, and I'd like the option to export a .sd to archive before I delete a service entirely from a server.
