Disable Editor Tracking in Pop-up for Enterprise Feature Layers
2654
06-11-2019 06:48 AM
Status: Implemented
Amanda__Huber
MVP Regular Contributor
It appears that the ability to disabe editor tracking is only supported in AGOL Hosted Feature Layers and not Enterprise Feature Layers. It would be awesome to also have this functionality for Enterprise Feature layers as well. (Enhancement request #ENH-000118710 , case #02230037 ).
Please see justification below:
The user uses a federated ArcGIS Server as their hosting server. The user has set up a distributed collaboration between their Portal for ArcGIS and ArcGIS Online, and then shared their server services to ArcGIS Online as collaborated contents.
Within the latest ArcGIS Online, users should be able to select whether to "show when last edited" for their feature services on the pop up configuration according to this article: https://www.esri.com/arcgis-blog/products/arcgis-online/announcements/new-arcgis-online-functionality-supported-by-customer-ideas-december-2018.
However, this option is not available on the pop up configuration of the user's collaborated contents (server services) even though the user had enabled editor tracking when they published the feature layer. It turns out this functionality is only available for hosted feature layers, because "show when last edited" option is considered one of the editing settings, and users cannot enable or modify editing settings for server services from ArcGIS Online.
3 Comments
ThomasEdghill
Hi @Amanda__Huber , I wanted to follow-up on this idea from 2019. In looking at the associated Enhancement Request, I see that it was closed as "Non-Reproducible" with the following note:
Please make sure that the server service has 'keep track of who created and last updated features' option enabled
I wanted to see if this issue is still something that you're facing? If not, I'll go ahead and close this idea. Thanks!
Amanda__Huber
@ThomasEdghill it appears this issue has been resolved (hooray!) I just tested one of our services and it appears that unchecking the "Show when last edited" respects enterprise layers.
Thanks so much!
-Amanda
ThomasEdghill
Hi @Amanda__Huber - I'm glad to hear that this is addressed now! I'll go ahead and mark this idea as Implemented. Thanks!
