Be Able to Define Timezone Parameter When Bulk Publishing from Data Store Item
1926
08-19-2020 08:03 AM
Status: Open
JoeGuziStarkCountyOH
Greetings,
When testing Bulk Publishing from a data store item, I came across an issue where my data wasn't showing up because my data had editor tracking enabled, and it was set to database time (eastern standard time). In order to set the the timezone parameter, I would have to long into arcgis server manager and set the timezone parameter for each of the 19 services I bulk published from the data store item. This is not very convenient.
There I propose, that you be able to set the timezone parameter prior to publishing the layers in bulk from a data store item. There needs to be some way to define this ahead of time. Another option would be for the publishing workflow to use the connection file to access the data, and read the editor tracking settings, then apply the appropriate timezone parameter settings to the published layers. Either way would be an improvement to the current workflow.
Thank you for entertaining this idea. Thank you for everything and have a delightful day.
Sincerely,
Joe Guzi
4 Comments
Joshua-Young
I ran into the same issue when trying to use bulk publishing. Thankfully, I only had a few layers that had edit tracking enabled at the time. I am looking to bulk publish several more GIS layers now, but they all have edit tracking in database time enabled. I am starting to wander if it would be a better use of time to disable edit tracking, convert the times to UTC, re-enable edit tracking, and then bulk publish.
I am contemplating this because it is going to take a while to go into the properties of every service to set the time zone, and I am concerned I will have to do this after every sync.
JustinMallinckrodt
Hello @JoeGuziStarkCountyOH & @Joshua-Young ;
Prior to ArcGIS Enterprise 11.1, date and time values in bulk-published layers used the time zone of the referenced database, and date and time values in the published layers were always rendered in UTC in ArcGIS Enterprise.
Now, when you synchronize bulk-published layers, you can define the time zone for date and time fields to be stored with the related map image and feature layer items, and you can define a time zone to use when viewing the date and time data in ArcGIS Pro.
Manage bulk-published layers—Portal for ArcGIS | Documentation for ArcGIS Enterprise
Please let me know if this resolves the problem you're both facing.
Greetings @JustinMallinckrodt,
I just tested this new workflow at AGE version 11.2 and it does exactly what I need it to do. This streamlines the workflow significantly.  Thank you for considering and implementing this change. I appreciate it. Thank you for everything and have a delightful day.
Sincerely,
Joe Guzi
JustinMallinckrodt
Thanks for the update @JoeGuziStarkCountyOH - I'm so glad to hear everything is working as expected for you after upgrading to 11.2!
