ArcGIS Server Look and feel with dynamic and interactive UI
- Need option to give Custom Date Range for filtering logs. Instead of just 4 to 5 options that we currently have
Something similar to this where we can give different dates and time range.
2. Text Search/Filter option under Message section so that we can check specific errors
3. Under Source – It should actually show the Source application from where the call is made. It helps in determining which application is using which specific services and if there are failures it will be easy to determine.
4. Global search should be made available so that one need not go into specific Folder and then search the service. See pic below—p2b search at Site level gives no results.
We have to go to Folder level and then search the map services.
5.Archiving option to archive map services that are currently not in use .
6.Renaming Map services for Published Services.
