Add setting to Portal Map Viewer to view field values in the time zone they were published (not converted to local time of viewer)
799
04-15-2024 12:47 PM
Status: Open
BryanPT
The Portal for ArcGIS Map Viewer displays time stamp values for time enabled layers to the local time zone of the person viewing the data, regardless of time zone settings applied to the published layer. There are many applications when analysts and users need to view temporal data in the time zone it was collected. For example, it is very frustrating when the Portal map viewer converts incident data that occurred in say Paris, France to US Eastern time only because the Portal user is located in the Eastern time zone. This makes the temporal analysis and visibility map viewer tools mostly useless when viewing event data far away from one's local time zone.
Interestingly, ArcGIS Pro and ArcGIS Server seem to honor time zone settings when Portal for ArcGIS does not.
2 Comments
TanuHoque
@BryanPT
we have already made this enhancement in ArcGIS Online Map Viewer.
and it should come to enterprise portal soon.
Just in case you can't wait, you can use a workaround for the time being. The workaround is to set the time zone to unknown. And it only supported by map services and by-ref (aka non-hosted) enterprise feature services.
you can learn more about that here:
https://www.esri.com/arcgis-blog/products/arcgis-online/announcements/arcgis-online-map-viewer-suppo...
pls let us know if you have any questions or feedback.
BryanPT
Thank you @TanuHoque . Your response was very helpful. I was able to use the workaround you provided in the link. However, I could only get it to work in an 11.2 Portal Map Viewer. The 10.9.1 Portal Map Viewer still converted timestamps to local time even when the time zone was set to Unknown. We are looking forward to further enhancements on this for ArcGIS Enterprise.
