Add a transformation parameter to the Geomery Service "Project" operation
1158
04-14-2011 03:45 AM
Status: Open
JanCreupelandt
The "Project" operation is only able to project a geometry correctly, when both projection id's (in and out), are based on the same datum. The REST API should be extended, so a transformation parameter can be added if needed. As a logic consequence the JavaScript/Flex and Silverlight API must have the possibility to define the transformation when projecting a geometry.
2 Comments
KelvinShum
Agree! This helps to plot maps with our local grid coordinate system.
JustinMallinckrodt
Hello @JanCreupelandt - I realize that this post is aged but this is supported via the REST API now.
Project—ArcGIS REST APIs | ArcGIS Developers
