Ability To Rename Service Name
1895
05-22-2020 03:01 PM
Status: Open
AdrienLepoutre
We would like to be able to change the REST name of web services in Portal and AGOL.
There is documentation indicating this could be possible but after testing it with ESRI analyst, renaming the REST name, at first glance, does not seem possible. The analyst is currently seeking additional resource to look into this issue andto be sure that renaming service is not supported.
The documentation is:
Rename Service with ArcGIS REST API (doesn't work)
How To: Change the name of a feature service  (changes only feature layer)
Update Definition (Feature Service)—ArcGIS REST API: Services Directory | ArcGIS for Developers (payload doesn't stick)
This idea change is related to the following post:
Updating Title of Hosted Feature Layer getting Updated via Script
1 Comment
chris_del101
Wow, surprising there are no other comments here supporting this idea. This post is from 2020 and in 2025 it still seems impossible to change the URL name of a service.
This should be a supported feature.
