SOI & RequestID
2767
05-27-2024 02:55 PM
TrevorH_OPE
Hello
At ArcGIS Server 10.7 the "Request ID", aka requestId, was added to the service logs.
Is it possible to get the requestId in a SOE/SOI? I dont see any refererences to requestId in the SDK (Java) documentation.
The request properties contains ETag but this isnt the requestId.
Thanks
TrevorH_OPE
Bueller…?
TrevorH_OPE
Anyone…?
TrevorH_OPE
giphy
LorenCress
@TrevorH_OPE
I have an answer for you!
import java.io.IOException;
import com.esri.arcgis.system.EnvironmentManager;
import com.esri.arcgis.system.IServerEnvironment;
import com.esri.arcgis.system.IServerEnvironmentProxy;
import com.esri.arcgis.system.UID;
class whatever
	public static UUID getRequestID() throws AutomationException, IOException
        EnvironmentManager envMgr = new EnvironmentManager();
        try
            UID envUID = new UID();
            envUID.setValue("{32d4c328-e473-4615-922c-63c108f55e60}");
            Object envObj = envMgr.getEnvironment(envUID);
            IServerEnvironment env = new IServerEnvironmentProxy(envObj);
            var reqIdStr = env.getProperties().getProperty("RequestID");
            if (reqIdStr != null)
                UUID reqId;
                try
                    reqId = UUID.fromString(reqIdStr.toString());
                    return reqId;
                catch(IllegalArgumentException e)
                return UUID.randomUUID();
            else
        finally {
            envMgr.release();
TrevorH_OPE
OMG @LorenCress thank you so much, I will test this out ASAP 😄
