Server Object Interceptors
2135
04-21-2023 03:29 AM
Labels (2)
Shanmukha_KumariVattem
We have create a project in C# for Server Object Interceptors (SOI) for getting server logs who opened services.
and added extension file in server manager extension as below screen.
And enabled interceptor in service capabilities interceptors section as in below screen
But we are unable to see the logs in server logs who opened the service like username
Ans also we have enabled for write the logs in JSON file in service capabilities but it is not writing into that file
nicogis
see this sample arcgis-enterprise-sdk-resources/Samples/dot net/SOI/NetSimpleLoggerSOI at master · Esri/arcgis-enter...
Anyway in the log you see the level you have enabled. If you set 'warning' you don’t see 'info' logs but only error and warning.
SFurey
For anyone still interested, the link above does not work, here's a link to the simple logger example
https://github.com/Esri/arcgis-enterprise-sdk-resources/tree/master/Samples/dot%20net/SOI/SimpleLogg...
