IGISServerConnection2 conn = new GISServerConnectionClass(); Conn.Connect(); Returns Class not registered error
6162
12
09-02-2020 04:47 AM
AmitabhaSarkar
I am executing following code from VS 2019 from a ServerObjectExtension and getting error gisConnection.Connect().
            IGISServerConnection2 conn = new GISServerConnectionClass(); //GISServerConnection()
            conn.Connect2("arcgis","NTPCSRV01"); --- Returns error
            conn.Connect( "NTPCSRV01"); -- Returns error
Error Message - System.Runtime.InteropServices.COMException HResult=0x80040154 Message=Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG)) Source=ESRI.Server.Server
Even if I referenced ESRI.ArcGIS.Server then also I receive similar error.
AmitabhaSarkar
Yes, I can connect to ArcGIS Server 10.0 but not 10.8.1
nicogis
MVP Alum
In fact 10.1 or superior doesn't use dcom
AmitabhaSarkar
Thanks for the confirmation, then what is alternative I need to access Server Object Manager and Create ServerContext. Many thanks in Advance.
