Migrate Content for ArcGIS Enterprise/ArcGIS Online
89369
171
01-02-2024 09:36 AM
It's always a good practice to have a DEV/STAGING environment along with a PRODUCTION environment for ArcGIS Enterprise. I frequently get asked how to migrate content from one to the other.  Hosted services can be straight forward, and can easily be scripted (expect an update later to this toolset for this functionality), but referenced services can be rather difficult. For example, there are numerous prerequisites that are required for a service to be published from an Enterprise Geodatabase, such as:
  • does the ArcGIS Service Account have necessary privileges
  • is the geodatabase registered with the ArcGIS Server instance
  • does the feature class in fact exist within the new geodatabase
  • etc
These tools pick up once your services have been published to the other environment and you would like to begin migrating web maps, apps, and dashboards. Take a look at the video below on how to execute these tools.
These tools should only be used to migrate web maps/apps where the environments are the same version (i.e. 11.1).  Migrating content between two ArcGIS Online organizations is also supported.
Currently, these tools have only been tested in ArcGIS Enterprise 11.1 and ArcGIS Online. If there are any issues, please report in the comment section below.
Migrating Referenced Services:
Updates
1/16/24:  Added tools to copy hosted feature services and file based items.
1/29/24:  Added option to run when portal has Windows Authentication enabled.  Also, updated the Copy Dashboard tool to specify stand-alone layers.
2/12/24:  Web Map item IDs now update
3/28/24:  Added tool to copy Story Maps
6/30/24:  Group layers and tables are now supported when copying web maps
7/10/24: Experience Builder Templates are now supported
5/1/25:  Web Scenes are now supported
6/14/25:  Updated for ArcGIS API 2.4.1
10/6/25:  Referenced services are now supported
10/28/25:  Hosted Views and Surveys are now supported
Known Issues
  • If hosted feature services exist in Enterprise, they will not successfully overwrite when executing the Copy Hosted Feature Services tool.  Will successfully overwrite in AGOL.  Possible bug with ArcGIS API for Python
  • After Story Map is copied to Enterprise, the Story Map must first be opened in Edit mode and published before it can be successfully viewed.  This is not the case for AGOL.  Possible bug with ArcGIS API for Python
Comments
ebpip
@JakeSkinner I am not seeing any new view created on the other account.  This is all within AGOL.  From one organiztional account to another.
JakeSkinner
Esri Esteemed Contributor
@ebpip can you share the feature service and view to a group and invite my AGOl account (jskinner_rats)?
ebpip
@JakeSkinner Thanks, I've share a group with the hosted and view layer.
JakeSkinner
@ebpip I made some updates to the Copy Views and it should work now.  I noticed that there are issues with it if you the feature service has been copied to the Target environment using the Copy Hosted Services tool.  The view will be created, but it will be blank.  Not quite sure what is causing this.  I'm currently testing with the latest ArcGIS for Python API 2.4.2.
So, you may need to publish the hosted feature service to the target environment using ArcGIS Pro.
NicolasRoux
Hi Jake,
I'm working with ArcGIS Enterprise 11.5 and testing the tool for copying referenced services.
Users have the necessary permissions for the various GIS resources: NAS, server, etc.
The source and target ArcGIS Enterprise instances are federated between their machines.
But I encounter this error:
Copy Referenced Services
Tool Path
D:\my\path\tothetoolbox\Migrate Content.atbx\CopyReferencedServices
Settings
Source Portal URL https://hostname/portal
Source Portal Windows Authentication Enabled false
Source Admin Username portaladmin
Source Admin Password *****
Source User [email protected]
Content serviceI - Map Service - id whatever
Enterprise Geodatabase 'SERVER=db, DATABASE=schema user, USER=user schema' 'D:\connection.sde'
File Geodatabase
Shapefiles
Target Portal https://target_hostname/portal
Target Portal Windows Authentication Enabled false
Target Admin Username portaladmin
Target Admin Password *****
Target Owner portaladmin
Target Folder Test
Target ArcGIS Server Instance https://target_hostname/server
Target ArcGIS Server Folder Test
Messages
Start Time: Friday, March 13, 2026 4:36:28 PM
Signing into source portal
Signing into target portal
Current user xyzx does not have access to \\machine\\\storage_files\dir\arcgisserver\directories\argissystem\arcgisinput\name\service.MapServer\extracted\p30\service.msd
Failed script Copy Referenced Services...
Failed to execute (CopyReferencedServices).
Failed on Friday, March 13, 2026, 4:36:34 PM (Elapsed Time: 5.71 seconds)
Is there a restriction on my end regarding the script's execution?
I'm surprised by the path given to read the MSD file, given that it's stored on this network volume.
Can you shed some light on this?
I can provide further information if needed.
Thank you
JakeSkinner
@NicolasRoux on the machine where you running the tool, add the path mentioned in the error as a folder connection to Pro.  There should be a MAPX file there.  Are you able to successfully import this file into ArcGIS Pro?
ebpip
@JakeSkinner Thanks for the help.  I'll try to copy the view again today.  Appreciate it!
NicolasRoux
@JakeSkinner : the machine can't reach the file targeted. That's the point to do : open the path to the .mapx file.
I'll keep you updated.
Problema:
Estoy migrando contenido entre dos organizaciones de ArcGIS Online usando la toolbox Migrate Content. Primero ejecuto Copy Hosted Feature Services y el Feature Layer se copia correctamente en el destino con una nueva URL. Luego uso Copy Web Map configurando el Previous Service URL y el New Service URL.
Resultado:
El proceso termina como “Succeeded”, pero el Web Map copiado sigue apuntando al servicio original en lugar del nuevo. Esto se confirma tanto en “Elementos utilizados” como en el JSON del mapa.
Pregunta:
¿Existen casos en que Copy Web Map no reemplaza las URLs? ¿Se requiere coincidencia exacta (encoding, sublayers, etc.) o hay limitaciones conocidas?
JakeSkinner
Hi @LlamasObservatorioEcuatoriano,
¿Es esto reproducible con todos los mapas web?
DavidMarquette
On some of my experience builder apps I am getting this when selecting the content:
\Migrate Content\Migrate Content.atbx\CopyExperienceBuilderApp.tool\tool.script.validate.py", line 177, in updateParameters
KeyError: 'utilities'
I believe its error-ing when trying to fill out the "Other Content" urls.  Any suggestions?  11.3
JakeSkinner
@DavidMarquette re-download the tools and give those a try.
DavidMarquette
That did it!  Thanks!
RahulRaj2025
Hello @JakeSkinner ,
I was migrating an Experience Builder app from AGOL to Enterprise version 11.5, but I encountered an error where the web map does not load properly in Experience Builder after migration (although manually adding the web map worked). Additionally, some widgets are not functioning due to version mismatches in version 11.5, which is understandable. I know you mentioned that the tool is mainly intended for online-to-online or portal-to-portal migrations. Could you please recommend an alternative method to migrate the Experience Builder app from Online to Portal? The rest of your suggested workflow worked fine for me.
Thanks in advance!
JakeSkinner
@RahulRaj2025 you can try the clone_items method from the ArcGIS API for Python:
https://developers.arcgis.com/python/latest/guide/cloning-complex-apps/#web-experiences
However, migrating an Experience Builder app from AGOL to Enterprise may require a custom script.
khem1000
@JakeSkinner thank you for sharing this
Is there any documentation on  the scripts and how to run them?
I understand the approach you've scripted is based on migrating by item types.
I need to migrate from one AGOL to another, and have about 9000 items, including
Storymaps, ExB apps, Survey 123 forms, dashboards etc.
I am wondering whether to migrate by item types e.g. Data files -> Hosted content -> Webmaps, webapps etc -> Complex items like Dashboards, Hub Sites etc
Or migrate each application with all its dependencies at a time, or a hybrid approach
Any suggestions ?
JakeSkinner
Hi @khem1000,
With 9000 items to migrate I use a different set of scripts.  Unfortunately, I cannot share these here.  It uses the same logic as these scripts but does things in batch.  For example, the order of each script:
  • Report Items - this creates a File Geodatabase table of all content within AGOL.  There is a MIGRATE field that defaults to 'Y', indicating it should be copied
  • Copy Users
  • Copy Groups
  • Copy Surveys
  • Copy Hosted Services
  • Copy Views
  • Copy File Based
  • Copy Web Maps
  • Copy Web Apps
  • Copy Dashboards
  • Copy Exp Apps
  • Copy Story Maps
khem1000
Hi @JakeSkinner ,
Thanks for the response. It sounds like you have tested migrating large number of items.
By batch, do you mean either 1) identifying the dependencies for say a batch of web applications, then migrating all items relating to these apps?
Or 2) migrating a batch of say, 100 hosted services at a time until all the services are done, then repeat for other item types ?
 I assume you meant option 2)
But if it is option 1), do you then use the MIGRATE field to prevent duplicates?
JakeSkinner
@khem1000 by batch, I mean migrating all services, then all views, then all web maps, etc.
Each script for content (i.e. services, web maps, apps, etc) creates an output table in a File Geodatabase that contains the source info and target info.  This information is used by additional scripts.  For example, the Migrate Hosted Feature Services script creates an output table like below:
Then, when the Migrate Web Maps is executed, it reads this table to do a find/replace of the services in the web map.  The Migrate Web Maps script also creates another table in a File Geodatabase to be used by the scripts for the app migrations:
khem1000
Thanks.
@JakeSkinner Is there reason why you are not using clone_items to simply copy items and all its dependencies ?
JakeSkinner
@khem1000 I personally never had much success with that function.
Version history
Last update:
‎04-14-2026 08:45 AM
Updated by:
Contributors
