Migrate Content for ArcGIS Enterprise/ArcGIS Online
89092
171
01-02-2024 09:36 AM
It's always a good practice to have a DEV/STAGING environment along with a PRODUCTION environment for ArcGIS Enterprise. I frequently get asked how to migrate content from one to the other.  Hosted services can be straight forward, and can easily be scripted (expect an update later to this toolset for this functionality), but referenced services can be rather difficult. For example, there are numerous prerequisites that are required for a service to be published from an Enterprise Geodatabase, such as:
  • does the ArcGIS Service Account have necessary privileges
  • is the geodatabase registered with the ArcGIS Server instance
  • does the feature class in fact exist within the new geodatabase
  • etc
These tools pick up once your services have been published to the other environment and you would like to begin migrating web maps, apps, and dashboards. Take a look at the video below on how to execute these tools.
These tools should only be used to migrate web maps/apps where the environments are the same version (i.e. 11.1).  Migrating content between two ArcGIS Online organizations is also supported.
Currently, these tools have only been tested in ArcGIS Enterprise 11.1 and ArcGIS Online. If there are any issues, please report in the comment section below.
Migrating Referenced Services:
Updates
1/16/24:  Added tools to copy hosted feature services and file based items.
1/29/24:  Added option to run when portal has Windows Authentication enabled.  Also, updated the Copy Dashboard tool to specify stand-alone layers.
2/12/24:  Web Map item IDs now update
3/28/24:  Added tool to copy Story Maps
6/30/24:  Group layers and tables are now supported when copying web maps
7/10/24: Experience Builder Templates are now supported
5/1/25:  Web Scenes are now supported
6/14/25:  Updated for ArcGIS API 2.4.1
10/6/25:  Referenced services are now supported
10/28/25:  Hosted Views and Surveys are now supported
Known Issues
  • If hosted feature services exist in Enterprise, they will not successfully overwrite when executing the Copy Hosted Feature Services tool.  Will successfully overwrite in AGOL.  Possible bug with ArcGIS API for Python
  • After Story Map is copied to Enterprise, the Story Map must first be opened in Edit mode and published before it can be successfully viewed.  This is not the case for AGOL.  Possible bug with ArcGIS API for Python
Comments
RafaelFernandesdeSouza
@JakeSkinner, Yes,
I will send two different screenshots, one without the error, with one webmap, and then, another with the error, when I select the other webmap.
JakeSkinner
Esri Esteemed Contributor
@RafaelFernandesdeSouza I would need to take a look at the web map to see what's going on.  Could you share the web map and services to a Group and invite my AGOL account (jskinner_rats) to this Group?
@JakeSkinner, I am sorry, but the webmap is from a client.
The difference between the webmap that works fine, and the ones that do not work, is that the webmaps that have feature collections added don't work, and if I remove the feature collections, they work.
Is there any problem with feature collections?
JakeSkinner
@RafaelFernandesdeSouza I just updated the toolbox validation to exclude feature collections in the Copy Web Map tool.  Re-download the zip file and see if the version works.
@JakeSkinner, Now, I got no errors loading the webmap
In this case, I can just add the feature collection layer later, right?
Thank you so much!
I think that the .zip file to download was replaced to only .atbx file.
OfraAi
Hello @JakeSkinner
You've developed a great set of tools. Thank you.
I've used it to copy from AGS 11.3 to AGOL (5.2025) for web maps, dashboard and experience builder. It worked 99%.
In the web maps, the visibility range of non default range in the layers was wrong. Instead of streets - rooms, it was change to streets - building.
I've fixed it easily in the web map designer, but I'm writing it for your knowledge.
Thank you
ofra
SedaKahraman
Hello @JakeSkinner
First of all, thank you very much for the tool, you are great.
I am getting the error shown in the attachment. The portal version is 10.6.1. Could the error be due to the version because I do not encounter any problems when I try it via the 10.9.1 portal url.
JakeSkinner
Hi @SedaKahraman remove the /home/ from your Portal URL.
PeterKnoop
MVP Regular Contributor
@JakeSkinner in order for "Copy Hosted Services.py" to support copying very large hosted feature layers, I would suggest updating your use of the export method to be asynchronous (i.e., set the wait parameter to False, and monitor the export job's progress with status) Otherwise the script can fail unexpectedly due to a timeout.
stevetaylor_perth
Hi Jake,
Thank you for this toolset.
Just noticed that when copying web maps the itemId for the map service does not get updated to new itemId in the destination portal.
The map still draws as it uses the URL of the service, but when going to the Map Item in Portal and clicking on the layer from the item details in Portal it comes up with "item not found", as the itemId is still the source itemId and not the destination itemId.
Is it possible to update the itemIds ?
JakeSkinner
@stevetaylor_perth this functionality exists in the script:
The script will search each portal using the URL of the service to get the Item Ids.  It will then perform a find/replace within the web map's JSON.  I would search each portal using the URLs to make sure items are being returned.
stevetaylor_perth
Hi Jake - thanks for getting back to me
I am investigating the issue - seems like the target portal cannot find the itemId by url
KevinMorrow
Hi Jake,
We uploaded a few 3D BIM models into AGOL as web scenes a few years back. Now our portal is upgraded to 11.3 we want to load the data local, but the person with original files is no longer with us, so we want to clone them from AGOL to the portal. I found your great tools while searching and tried the webscene copy you added a few months back but I keep getting errors.
Start Time: Tuesday, September 16, 2025 8:13:00 PM
Signing into source portal
Signing into target portal
Getting Web Scene ID
Getting Web Scene JSON
Converting dict to JSON
Replacing service URLs
File "C:\Work\Migrate Content\Copy Web Scenes.py", line 75, in <module>
lyr2 = layers[x].split(" ")[1]
IndexError: list index out of range
Failed script Copy Web Scene...
Failed to execute (CopyWebScene).
Failed at Tuesday, September 16, 2025 8:13:06 PM (Elapsed Time: 6.06 seconds)
Any ideas.? Has anyone else tried the web scene copy yet?
Regards,
Kevin.
RafaelFSouza
Is there any update to migrate referenced services?
JakeSkinner
@RafaelFSouza I may have this completed in the next week.
JakeSkinner
@RafaelFSouza referenced services are now supported.
JakeSkinner
@KevinMorrow I'm not an expert with Web Scenes, but the issue may be going from AGOL to Portal.  What version of Portal are you running?  Also, if you want to share the Web Scene to a Group and invite my AGOL account, my username is 'jskinner_rats'.
GeoAKS
Hi All,
I was using it for Experience Builder Web App migration from one enterprise portal to another portal. Tool run successfully, item is created in target portal but its not working (failed to load).
Can someone confirm if tool works for experience builder app migration from AGOL to another AGOL organization?
JakeSkinner
Hi @GeoAKS, yes this works migrating an Exp Builder App from AGOL to AGOL.  Is this reproducible with all Exp Builder Apps?  I've noticed sometimes if you don't tab out of the Web Maps and  Other Content parameters, the tool will not pick up the pasted value:
You can also use the newer AGOL Assistant to see if the web map IDs are updating correctly.
admingeoweb
Hi @JakeSkinner
thank you so much for sharing this toolbox, I have been testing it and it works great.
What would you recommand to migration (copy) Instant App ?
Could it be the item in the content line of the python script ?
JakeSkinner
@admingeoweb you can use the Copy Web App tool to copy Instant Apps.
anonymous55
I am using ArcGIS Pro 3.6.0 and I am trying to connect to our ArcGIS Online environment, but I am receiving Error 032659. I can see that others have encountered this error in previous posts.
I am trying to move web maps from AGOL to Portal 3.11, but I keep getting this error.
However, I was able to successfully move dashboards and hosted layers from the QA Portal to the Production Portal environment.
Is it even possible to move items from AGOL to Portal? If so, how can I fix this error?
JakeSkinner
@anonymous55 you can move web maps and hosted feature services from AGOL to Portal, but not applications (i.e. Experience Builder Apps, Story Maps, Dashboards).  Can you post a screen shot of how you have the tool configured?
anonymous55
Hello @JakeSkinner
below is the screen shot of error also in arcpro I log in to arcgis online too.
JakeSkinner
@anonymous55 you will need to connect to AGOL with a built-in account.  Are you attempting to use a SAML account?
anonymous55
no we don't use SAML
JakeSkinner
@anonymous55 are you connecting to AGOL with an Administrator account?
anonymous55
Hello @JakeSkinner
I’m also making sure that I’m using the license from AGOL, but I’m still getting the same error.
I think I need to set a proxy for your tools, but I’m not sure how to do that. When I test simple Python code in Jupyter, I can’t connect to AGOL without using a proxy.
Is it possible for you to add a proxy option to your tools?
JakeSkinner
@anonymous55 yes, you can add a proxy to the tools.  You will need to add in the proxy details.  Ex:
proxy_settings = {
        'http': 'http://your_proxy_host:your_proxy_port',
        'https': 'http://your_proxy_host:your_proxy_port'
Then update each occurrence of the GIS module in the script and the tool's validation (right-click on script tool > Properties > Validation tab).  Ex:
ebpip
First, thank you for providing these valuable and seemingly rare tools, tough to find things so ready to use for these applications.
I am attempting to copy hosted feature services between two organizational AGOL accounts.  The connection between them and data transfer work, however I am receiving an error when it attempts to recreate the hosted feature layer on the target account.  It seems like the file GDB being created during the process is named the same as the hosted feature layer and throwing an excpetion.
I can see the GDB in the target folder, but unable to produce the copied feature layer.
JakeSkinner
@ebpip does the feature service StorwaterSystem exist in your Organization, possibly owned by another user?  Can you test another feature service to see if you get the same error?
ebpip
@JakeSkinner Thanks for the quick reply.  I did check and found a previously deleted version of the hosted layer on the target account in the recycle bin.  I permanently deleted it and the script was able to complete succesfully.  However, the new copy of the hosted layer on the target account is nearly empty.  It only resulted in two tables whereas the original has a dozen or so tables and about the same for layers, which I'm not seeing any of.  Any thoughts on resolution?  I tried with another hosted layer that is similar in makeup and it resulted in nothing being published to the new hosted layer, it is empty.
JakeSkinner
@ebpip can you share the service to an AGOL group and invite my account (jskinner_rats)?  I can take a look.
ebpip
@JakeSkinner I've shared stormwater with you, thanks a bunch for having a look.
JakeSkinner
Hi @ebpip, I was unable to reproduce this.  I downloaded the data and re-published to my Org as a service.  I then used the Copy Hosted Feature Service tool to copy to another org and it worked successfully:
I did this with ArcGIS Pro 3.6.
ebpip
@JakeSkinner Well ok then, thanks for testing it.  I will dig in a bit more and do some more testing on my end.  It may be something on the target org's AGOL.  I really appreciate you taking time to look into it.
VenkataKondepati
Honored Contributor
This migration guide is extremely helpful — it clearly outlines the steps and considerations when migrating content from ArcGIS Online into an ArcGIS Enterprise deployment. Having a structured walkthrough for items, groups, and dependencies makes the process much less daunting, especially for large orgs with lots of assets. Thanks for providing such a practical reference!
– Venkat
JohnnyMcGlone
Thanks for this! When Copying Web map, any reason why some maps would throw an error (doesn't populate content and has source org error) when most other maps are fine? All maps within one of my folder register and throw an error.
JakeSkinner
@JohnnyMcGlone is this for Enterprise or AGOL?  If Enterprise, which version?
JohnnyMcGlone
@JakeSkinner it's AGOL. I figured it out with some process of elimination. It was tied to a reference layer I was using and another service layer. Luckily I can do without them.  The tool let me proceed once I removed them and saved the source web map. Thanks!
denisCallens
Hi @JakeSkinner ,
again thank you for this great tool! Recently I use it a lot.
Here are some bugs that I found (i am on enterprise 11.5 and AGS pro 3.5) :
  • Copy web map
    • If you have nested group layer (a group layer inside a group layer inside a group layer ...), validation fail (around line 150)
    • Same problem if you have VTPK in your map
    • If you use "copy web maps", you cannot use "field map designer" on the target portal. I noticed that this tool uses the itemid of the layer. Editing this parameter in agol assistant solves my problem.
  • Copy Experience Builder App
    • Link to the print service is not updated. You have to do it manually after migration
    • Same problem if you have a custom widget
Hope this will help any other user
JakeSkinner
Thanks for the feedback @denisCallens.  I was able to update the tools to resolve the above issues.  However I was unable to reproduce the Field Map Designer issue.  I'll do some additional testing and circle back if I am.
HelenWhiteley_tfl
Thanks @JakeSkinner this looks like a great tool and will save us a lot of time! A couple of observations on first use however...
  1. I've migrated a map with a feature service and a map service - both service URLs are updated, but the item ID for the feature service points to the item in the first portal - am I missing a step? The map still works, and we can update the ID in AGO Assistant, but it would be nice to cut AGO Assistant out of the process.
  2. Also, it would be useful in future to be able to re-path base maps as well, as we use internal custom base maps, and need to re-path these.
JakeSkinner
@HelenWhiteley_tfl I could not reproduce the item ID issue.  This is incorporated into the code:
Is the Feature/Service Map Service added as an item in the target portal?  Are you using Enterprise?  If so, which version?
Also, I'll look into adding the ability to re-path basemaps.
ebpip
@JakeSkinner I'm trying to use Copy Views to move views between two organizations.  It gives it a go and then I receive the error message below.  Any thoughts on a resolution?  Thanks for the tools and the help.
JakeSkinner
@ebpip the tool will search the target portal for the parent feature service the view is to be created off of.  It looks like it's finding a File Geodatabase instead of the feature service.  First, verify you have the parent feature service in the target org.  Then, check if you have a File Geodatabase with the same name of the feature service.  If you do, delete it and try executing the tool again.  I may have to update the code to return only feature services during the search process.
JakeSkinner
@ebpip I updated the Copy Views tool.  Can you re-download these tools and try again?
ebpip
@JakeSkinner Will do that today, thanks!
ebpip
@JakeSkinner
I gave the new tool a go.  Returned a different error this time.  See below and thank you.
JakeSkinner
@ebpip looks like the script is having trouble finding the new view to update the settings.  Can you verify the new view was successfully created?
Also, are you migrating from AGOL to AGOL, or Enterprise to Enterprise?  If the latter, what version of Enterprise?
Version history
Last update:
‎04-14-2026 08:45 AM
Updated by:
Contributors
