Updates to OpenStreetMap Vector Basemap Styles in ArcGIS Enterprise
1370
06-15-2021 04:15 PM
Andy-Green
As we recently announced, the OpenStreetMap vector basemaps on ArcGIS Online will be updated to use OSM Daylight distribution data content. Another blog we posted details the impact to users of OSM basemap styles. Here in this post, we will provide details on the impact to ArcGIS Enterprise users who are using these services via Living Atlas. The changes to the map styles applies to both the Web Mercator Auxiliary Sphere (WMA) and WGS84/GCS OSM vector basemaps. The change to the underlying source data that requires these new styles was released on Wednesday night, June 16, 2021.
ArcGIS Enterprise organizations using these OpenStreetMap layers by referencing them directly from ArcGIS Online are not affected by this update. In this scenario, the styles are referencing the most up to date Online items.
Impact to OpenStreetMap Vector Basemap Users in ArcGIS Enterprise 10.8, 10.8.1 or 10.9
To take advantage of the enhancements for OpenStreetMap vector basemaps in ArcGIS Enterprise and display OpenStreetMap tile layers correctly, your administrator will need to update the OpenStreetMap Living Atlas items installed on your ArcGIS Enterprise portal.
OpenStreetMap tile layer items are included with Living Atlas default content at 10.8, 10.8.1, and 10.9. Use the table below for a complete breakdown of items included at each version.
Step 1
  • There is an item on ArcGIS Online with the updated root.json styles for all the styles listed below.
  • Download and unpack the contents of the zipped directory. Unpacked, the folders are organized by map projection/tiling scheme and by ArcGIS Enterprise version.
  • Folder names for each style are listed by their item ID. Each folder contains a root.json file.
  • This is the file you’ll use to update the different OpenStreetMap Tile Layer styles on your portal.
Step 2
  • Update each OpenStreetMap item in your portal.
  • Navigate to the item details page for each item.
  • Select the “Update” button.
  • Navigate to the correct folder containing the updated root.json file.
  • Match the item ID of your portal item with the item ID of the directory
  • Update each style.
  • You may need to clear your browser cache to see the updates.
Tile Layer Title
(links here open the item in ArcGIS Online, use as a reference to the map title)
ITEM ID
(these match the style directory names to update the OSM tile layers in your portal)
Web Mercator Aux. Sphere (WMA)
OpenStreetMap3e1a00aeae81496587988075fe529f7110.810.8.110.9
OpenStreetMap (with Relief)0d28c37f80f648238e32efce097450f1 10.8.110.9
OpenStreetMap (Esri Dark Gray Canvas Base)cb38f2afc497482a85579dce4c3ff4ed  10.9
OpenStreetMap (Esri Dark Gray Canvas Reference)b49a8db3fe6e4f9f99cb713aee150e8d  10.9
OpenStreetMap (Esri Hybrid Reference style)f240fe360b434afc87dd989bf0c0b82510.810.8.110.9
OpenStreetMap (Esri Light Gray Canvas Base)1932e7d4432d45dabc0d4d13109c1f09 10.8.110.9
OpenStreetMap (Esri Light Gray Canvas Reference)29a71939af7a498584f44c4feca7249b 10.8.110.9
OpenStreetMap (Esri Street style)f455d84d5aab4d64b1191e0d2eed42b110.810.8.110.9
OpenStreetMap (Esri Street with Relief style)8f9cb35cec274e25b4c5d6add631f1f0 10.8.110.9
OpenStreetMap (Blueprint)80be160f0ca1413d898ad4e90d197278 10.8.110.9
GCS/WGS84 Tiling Scheme
OpenStreetMap (WGS84)cabd61a6cfc44843b2ccd6969bb88cf010.810.8.110.9
OpenStreetMap (with Relief – WGS84)7ecc5e5a3ba445de9e118d42833e6dbb 10.8.110.9
OpenStreetMap (Esri Dark Gray Canvas Base – WGS84)5d1479fbdb084edc8a91f44116181a5e  10.9
OpenStreetMap (Esri Dark Gray Canvas Reference – WGS84)5bf7ce751e4a42e8b218bedc1f94798f  10.9
OpenStreetMap (Esri Hybrid Reference – WGS84)e67de4be72b349fd8f8ca114bac82a8c10.810.8.110.9
OpenStreetMap (Esri Light Gray Canvas Base – WGS84)6d9a3c4768bc4090931e9ed3d94fd385  10.9
OpenStreetMap (Esri Light Gray Canvas Reference – WGS84)ea59b79df5a24e4ebad9bb6db828a623  10.9
OpenStreetMap (Esri Street style – WGS84)13100ed96b7a4e18b9a7c024c56910aa10.810.8.110.9
OpenStreetMap (Esri Street with Relief style – WGS84)8eaddf4279684fc09abb2b61f1338be4 10.8.110.9
OpenStreetMap (Blueprint – WGS84)58ca82eb9e1948a49e812fe90454e73e 10.8.110.9
Noticeable changes
After the source tile set is updated with OSM Daylight content on Wednesday night June 16, 2021, if the OSM tile layers on your portal are not updated, some map features will not display. View the Esri blog post to see examples of what the maps will look like if they are not, as well as are, updated.
Customers with questions can contact Esri Technical Support for assistance.
About the Author
I've been a mapping & GIS professional for twenty years before joining Esri in 2012. I started as a cartographer at Penn State and continued at Donnelley Cartographic, which morphed and merged into MapQuest.com. Away from work, I've enjoyed exploring Southern California's attractions from the beaches to the deserts and the urban gems in between. I can be reached at [email protected]
